주요 콘텐츠로 건너뛰기
Petzl E03 050 Headlamp Battery Replacement
필요한 것
  1. Petzl E03 050 Headlamp Battery Replacement, Remove the Cover: 1 단계, 이미지 1/1
    • Remove the back cover of the battery housing (found behind the mount assembly) by pulling the small tab on the bottom right corner.
  2. Petzl E03 050 Headlamp Battery Replacement, Remove the Old Batteries: 2 단계, 이미지 1/1
    • Remove the old batteries by pulling outward the positive end of each battery.
  3. Petzl E03 050 Headlamp Battery Replacement, Insert the New Batteries: 3 단계, 이미지 1/1
    • Insert the new batteries by inserting the negative end of the battery into the negative side of the battery compartment and pushing the positive end of the battery into the positive side of battery compartment.
  4. Petzl E03 050 Headlamp Battery Replacement, Reattach the Cover: 4 단계, 이미지 1/1
    • Reattach the back cover of the battery housing by pushing in the bottom half and then pressing the rest of the cover into place.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Mike
회원 가입일: 10/23/14
331 평판
안내서 3개 작성하였습니다
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G10
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 91
전체 시간: 5,265
