주요 콘텐츠로 건너뛰기
Petzl E03 050 Headlamp Elastic Strap Replacement
  1. Petzl E03 050 Headlamp Elastic Strap Replacement, Slide the Lefthand Strap: 1 단계, 이미지 1/1
    • Slide the lefthand portion of the elastic headband into the middle opening on the mount.
  2. Petzl E03 050 Headlamp Elastic Strap Replacement, Remove the Lefthand Strap: 2 단계, 이미지 1/1
    • Pull the lefthand portion of the elastic strap through the middle opening.
  3. Petzl E03 050 Headlamp Elastic Strap Replacement, Slide the Top Strap: 3 단계, 이미지 1/1
    • Slide the top portion of the elastic strap into the middle opening of the top bracket on the mount.
  4. Petzl E03 050 Headlamp Elastic Strap Replacement, Remove the Top Strap: 4 단계, 이미지 1/1
    • Pull the top portion of the elastic strap through the top bracket on the mount.
  5. Petzl E03 050 Headlamp Elastic Strap Replacement, Slide the Righthand-Upper Strap: 5 단계, 이미지 1/1
    • Slide the top layer of the righthand elastic strap into the middle bracket on the mount.
  6. Petzl E03 050 Headlamp Elastic Strap Replacement, Remove the Righthand-Upper Strap: 6 단계, 이미지 1/1
    • Pull the top of the righthand strap through the middle bracket on the mount.
  7. Petzl E03 050 Headlamp Elastic Strap Replacement, Slide the Righthand-Lower Strap: 7 단계, 이미지 1/1
    • Slide the bottom of the righthand elastic strap into the middle bracket on the mount.
  8. Petzl E03 050 Headlamp Elastic Strap Replacement, Remove the Righthand-Lower Strap: 8 단계, 이미지 1/1
    • Pull the bottom of the righthand strap through the middle bracket on the mount. The strap should now be completely free from the mount.
결론
To reassemble your device, follow these instructions in reverse order using your replacement Petzl elastic headband.
Princess
회원 가입일: 10/22/14
114 평판
안내서 1개 작성함
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G10
3 회원들
안내서 10개 작성하였습니다
댓글 2개
Any idea of how to replace the headband when my model doesn’t have those handy dandy slits in the brackets?
shiningwillow - 답글
Managed the rethread my old Petzl head torch. Let me know if you'd like a hand.
Marion Dubois - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 32
30일 전: 107
전체 시간: 9,088
