주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Does your headlamp produce dim lighting despite a fresh set of batteries and a bulb? You may need to replace the lens piece - especially if the reflective mirror has become damaged or dull.
도구
지정된 도구가 없습니다.
부품
  1. Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
    • Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
  2. Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
    • Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
  3. Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
    • Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
  4. Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
    • Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
결승점
Mike
회원 가입일: 2014년 10월 23일
314 평판
안내서 3개 작성하였습니다
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G10
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 385
