주요 콘텐츠로 건너뛰기
Petzl E03 050 Headlamp Light Bulb Replacement Guide
  1. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Check For Spare Bulb: 1 단계, 이미지 1개 중 1개
    • Check for a spare bulb in the spare bulb compartment located on the back of the battery housing (found behind the mount assembly). If no spare bulb is found in the spare bulb compartment you will need to purchase a replacement 3V incandescent bulb from a reputable retailer
  2. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Loosen the Lens Piece: 2 단계, 이미지 1개 중 1개
    • Turn the lens piece counterclockwise (left) until it is fully extended.
  3. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lens Piece: 3 단계, 이미지 1개 중 1개
    • Remove the lens piece by firmly pulling it away from the battery housing.
  4. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Remove the Lightbulb: 4 단계, 이미지 1개 중 1개
    • Turn the bulb counterclockwise (left) until it becomes free. Safely discard the old bulb.
  5. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Install the New Lightbulb: 5 단계, 이미지 1개 중 1개
    • Install the new bulb by inserting it into the socket.
  6. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Rotate Replacement Light Bulb: 6 단계, 이미지 1개 중 1개
    • Rotate the bulb clockwise (right) until it is firmly fixed in place.
  7. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Re-attach the Lens Piece: 7 단계, 이미지 1개 중 1개
    • Press the lens piece onto the front of the battery housing.
  8. Petzl E03 050 Headlamp Light Bulb Replacement Guide, Tighten the Lens Piece: 8 단계, 이미지 1개 중 1개
    • Turn the lens piece clockwise (right) to the “On” position. If the light fails to illuminate after turning the lens piece to the “On” position you may have to replace the batteries.
결승점
작성자
2다른 기여자 명과 함께
Carla
회원 가입일: 10/19/14
131 평판
안내서 1개를 작성함
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G10
3 회원들
안내서 10개를 작성함
3가이드 댓글
Ha I wonder how many people don’t even realize there’s a replacement readily available on their head! Thanks for sharing.
jmania - 답글
This was my father headlamp. Want to continue using it.. makes me feel like he is this with me
laura.odonnell52 - 답글
Is it also possible to replace the old 3v light bulb with an LED light?
bertkling - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 101
전체 시간: 5,954
