주요 콘텐츠로 건너뛰기
Philips BDL4231 LCD TV Power Supply Board Capacitor & Diode Replacement
필요한 것
    • Remove the 16 back cover screws.
    • Remove the six power supply board screws.
    • Remove the one power supply board 120V connector screw.
    • If needed remove the VESA mount 5 screws and loosen the other side 5 screws to position the brackets so the power supply board can be removed.
    • Remove the connectors to the power supply board, i.e. 120V connector and the three other connectors being careful to note placement of the two connectors on the left side that are close to each other.
    • Replace power supply following the previous instructions in reverse.
    • Remove the power supply board and bring to the location to be desoldered.
    • Desolder capacitors using the soldering iron and some flux and solder.
    • Desolder diodes using the soldering iron and some flux and solder.
    • Clean PCB trace locations with solder wick and isopropyl alcohol or cleaner. Solder new solder in location leaving hole still so components can be inserted.
    • Carefully noting polarity of the capacitor, place correct new capacitor(s) in PCB location(s).
    • Carefully noting polarity of the diode, place correct new diode(s) in PCB location(s).
    • Solder the components in place using flux and solder.
    • Follow step 2 in reverse to replace board, brackets if applicable and back cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Finch
회원 가입일: 10/14/17
2,268 평판
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 1,631
