주요 콘텐츠로 건너뛰기
Philips BiPAP S/T Blower Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
동영상 개요
  1. Philips BiPAP S/T Blower  Replacement, Blower: 1 단계, 이미지 1/1
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: 2 단계, 이미지 1/1
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: 3 단계, 이미지 1/1
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: 4 단계, 이미지 1/1
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: 7 단계, 이미지 1/1
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Benjamin LaVigna
회원 가입일: 04/07/20
243 평판
안내서 1개 작성함
Cal Poly, Team S7-G3, Paton Spring 2020 Cal Poly, Team S7-G3, Paton Spring 2020 회원
CPSU-PATON-S20S7G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 2,792
