주요 콘텐츠로 건너뛰기
Philips BiPAP S/T Humidifier Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Philips BiPAP S/T Humidifier Replacement, Humidifier: 1 단계, 이미지 1개 중 1개
    • Remove the Water Chamber Assembly.
    • Gently squeeze the latch on the Flip Lid Assembly to release it.
    • Lift the Flip Lid Assembly.
    • Pull the Humidifier Tank Assembly out of the Humidifier.
  2. Philips BiPAP S/T Humidifier Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the Tank Top Seal from the Flip Lid Assembly.
    • If this is the source of the error, put in a new one.
  3. Philips BiPAP S/T Humidifier Replacement: 3 단계, 이미지 2개 중 1개 Philips BiPAP S/T Humidifier Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the Dry Box Seal.
    • If this is the source of error, place this part with a new one.
    • When replacing, ensure that the narrow end of the seal is inserted into the Dry Box.
  4. Philips BiPAP S/T Humidifier Replacement: 4 단계, 이미지 2개 중 1개 Philips BiPAP S/T Humidifier Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the Dry Box Assembly.
    • Insert a flat blade screwdriver into the hole located on the back of the Humidifier and lightly press inward to release the Dry Box Assembly.
    • Do not press firmly on the screwdriver as damage may occur.
    • Remove the Inlet Seal from the Dry Box Assembly
  5. Philips BiPAP S/T Humidifier Replacement: 5 단계, 이미지 3개 중 1개 Philips BiPAP S/T Humidifier Replacement: 5 단계, 이미지 3개 중 2개 Philips BiPAP S/T Humidifier Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the Flip Lid Assembly.
    • Use a screwdriver to push in on the latches that secure the Flip Lid Assembly to the Humidifier Top Housing.
    • Bend the Flip Lid Assembly completely backwards until it is removed.
    • For Heated Tube devices, remove the wire harness from the base.
  6. Philips BiPAP S/T Humidifier Replacement: 6 단계, 이미지 1개 중 1개
    • Use a T8 Torx screwdriver to remove the four #4 x 1/2" screws that secure the Top Housing to the Humidifier Bottom Housing
  7. Philips BiPAP S/T Humidifier Replacement: 7 단계, 이미지 1개 중 1개
    • Slide the Outside Cover out of the Bottom Housing.
  8. Philips BiPAP S/T Humidifier Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the Left Side Panel.
    • Use a T15 Torx screwdriver to remove the four #6 x 1/4" screws that secure the Bottom Housing to the Lower Base Assembly.
  9. Philips BiPAP S/T Humidifier Replacement: 9 단계, 이미지 2개 중 1개 Philips BiPAP S/T Humidifier Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the Heater Plate Assembly.
    • The Heater Plate Assembly is secured by two small tabs.
    • Once replaced, secure the Bottom Housing to the Lower Base using the four #6 x 1/4" screws.
    • Be sure the Heater Plate Spring is properly seated under the Heater Plate.
결론
작성자
2다른 기여자 명과 함께
Courtney Huitt
회원 가입일: 04/07/20
169 평판
안내서 1개를 작성함
Cal Poly, Team S7-G3, Paton Spring 2020 Cal Poly, Team S7-G3, Paton Spring 2020 회원
CPSU-PATON-S20S7G3
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 410
