주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Philips Bluetooth adapter AEA2700 수리는 저희 서비스 설명서를 사용하십시오.
  1. Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: 1 단계, 이미지 1/3 Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: 1 단계, 이미지 2/3 Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: 1 단계, 이미지 3/3
    • here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
  2. Philips Bluetooth adapter AEA2700 Teardown: 2 단계, 이미지 1/2 Philips Bluetooth adapter AEA2700 Teardown: 2 단계, 이미지 2/2
    • Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
  3. Philips Bluetooth adapter AEA2700 Teardown: 3 단계, 이미지 1/1
    • now simply remove the top cover.
  4. Philips Bluetooth adapter AEA2700 Teardown: 4 단계, 이미지 1/1
    • there's only one external component connected by cable: the NFC tag
    • it's easily possible to remove the circuit
    • lift it on the front side of the device
    • and pull it this direction - it helps to push at the cinch connector!
  5. Philips Bluetooth adapter AEA2700 Teardown: 5 단계, 이미지 1/2 Philips Bluetooth adapter AEA2700 Teardown: 5 단계, 이미지 2/2
    • Front- and backview of the circuit
  6. Philips Bluetooth adapter AEA2700 Teardown: 6 단계, 이미지 1/1
    • when reassembling take care to stick the NFC tag to the correct location in the cover
RFischer
회원 가입일: 12/29/14
265 평판
안내서 2개 작성하였습니다
댓글 한 개
Hello. Is there any way to use this device in a car through an adapter or modification?
Fabio Passarelli - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 3,974
