주요 콘텐츠로 건너뛰기
Philips DC320 37 Connector Replacement
필요한 것
  1. Philips DC320 37 Connector Replacement, Docking entertainment system: 1 단계, 이미지 1/1
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Connector Replacement: 2 단계, 이미지 1/1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Connector Replacement: 3 단계, 이미지 1/1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Connector Replacement: 4 단계, 이미지 1/3 Philips DC320 37 Connector Replacement: 4 단계, 이미지 2/3 Philips DC320 37 Connector Replacement: 4 단계, 이미지 3/3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Connector Replacement, Connector: 5 단계, 이미지 1/1
    • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
  6. Philips DC320 37 Connector Replacement: 6 단계, 이미지 1/1
    • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
    • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
  7. Philips DC320 37 Connector Replacement: 7 단계, 이미지 1/3 Philips DC320 37 Connector Replacement: 7 단계, 이미지 2/3 Philips DC320 37 Connector Replacement: 7 단계, 이미지 3/3
    • Turn the dock so that you are looking at the front of the dock.
    • Pull out the black U-shaped piece.
    • Pull out the iPhone/iPod support cradle.
    • Pull out the two springs.
  8. Philips DC320 37 Connector Replacement: 8 단계, 이미지 1/1
    • Turn the dock so that you are looking at the bottom of the dock.
    • Pop out the black connector frame and attached circuit board from the body of the dock.
결론
Greg Lane
회원 가입일: 04/16/13
39 평판
안내서 4개 작성하였습니다
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G48
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 1,238
