소개
Follow the procedure outlined in this guide to remove and install a broken audio or power jack.
  1. Pry off the four white feet with the pointed end of the spudger
    • Pry off the four white feet with the pointed end of the spudger
  2. Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    • Unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock. Electrical Connectors Ribbon Connectors
    • Carefully pull up and out the four electrical connectors and the two ribbon connectors connecting the bottom panel and the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  6. Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  7. Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  8. Separate the white suport bracket from the headphone/power electronics board.
    • Separate the white suport bracket from the headphone/power electronics board.
결론
Graham Rolph
회원 가입일: 2013년 04월 18일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G48
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,048
