주요 콘텐츠로 건너뛰기
Philips DS3000 Speakers Replacement
필요한 것
  1. Philips DS3000 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Pry off the front fascia by inserting a plastic opening tool between the fascia and white casing.
  2. Philips DS3000 Speakers Replacement: 2 단계, 이미지 1/1
    • Pull the ZIF (zero insertion force) white ribbon out of the circuit board by hand located on the back of the front fascia. Be careful when pulling it out of the connector.
  3. Philips DS3000 Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the 10 screws from the black internal housing (6 black screws, 4 silver screws). They are all phillips #1 screws and the black screws are 10 mm in length and the silver screws are 8 mm in length.
  4. Philips DS3000 Speakers Replacement: 4 단계, 이미지 1/1
    • Slowly pry around the black housing with the plastic opening tool to remove it from the back housing.
  5. Philips DS3000 Speakers Replacement: 5 단계, 이미지 1/1
    • Remove the 4 phillips #1 head silver screws from the green circuit board. They are located on the four corners of the board and are 8 mm in length.
  6. Philips DS3000 Speakers Replacement: 6 단계, 이미지 1/1
    • Remove the black tube (speaker port) by unscrewing the silver phillips head #1 screw (8 mm in length) that connects it to the black housing. Pull it off from where it wraps around the black housing's mating port.
  7. Philips DS3000 Speakers Replacement: 7 단계, 이미지 1/1
    • Remove the 4 silver phillips head #1 screws from the back of the speaker that are 7 mm in length.
  8. Philips DS3000 Speakers Replacement: 8 단계, 이미지 1/1
    • Remove the speaker from the black housing.
  9. Philips DS3000 Speakers Replacement: 9 단계, 이미지 1/1
    • Remove about an inch of the black sponge insulation from around the red (positive) and black (negative) speaker wires.
  10. Philips DS3000 Speakers Replacement: 10 단계, 이미지 1/2 Philips DS3000 Speakers Replacement: 10 단계, 이미지 2/2
    • Use the soldering iron to heat up the terminal spots on the speaker and remove each wire (red and black).
  11. Philips DS3000 Speakers Replacement: 11 단계, 이미지 1/1
    • Strip about a quarter inch of the rubber insulation away from each of the speaker wires (red and black wires) using the 6 inch wire strippers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew McAuliffe
회원 가입일: 02/24/14
128 평판
안내서 1개 작성함
Michigan Tech, Team 5-7, Lauer Spring 2014 Michigan Tech, Team 5-7, Lauer Spring 2014 회원
MTU-LAUER-S14S5G7
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
araujojraa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 3,416
