주요 콘텐츠로 건너뛰기
Philips DVP5992-F7 Audio Video Port Replacement
필요한 것
  1. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: 1 단계, 이미지 1/3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: 1 단계, 이미지 2/3 Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: 1 단계, 이미지 3/3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Audio Video Port Replacement: 2 단계, 이미지 1/2 Philips DVP5992-F7 Audio Video Port Replacement: 2 단계, 이미지 2/2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Audio Video Port Replacement: 3 단계, 이미지 1/3 Philips DVP5992-F7 Audio Video Port Replacement: 3 단계, 이미지 2/3 Philips DVP5992-F7 Audio Video Port Replacement: 3 단계, 이미지 3/3
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 Audio Video Port Replacement: 4 단계, 이미지 1/1
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 Audio Video Port Replacement: 5 단계, 이미지 1/1
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 Audio Video Port Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard from the DVD player.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Dyllon Phuong
회원 가입일: 08/31/18
540 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 288
