메인 콘텐츠로 스킵하기
소개
Over time, the HDMI port can become unresponsive. This guide will show you how to replace an unresponsive HDMI port on your Philips DVP5992-F7.
부품
지정된 부품이 없습니다.
  1. Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver. Remove the 6.4 mm Phillips #1 screws on each side of the device. Remove the 6.4 mm Phillips #1 screws on each side of the device.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Remove the top plate of the DVD by firmly grasping the player on both sides. Shift the top plate towards the backside of the player.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard. Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard. Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Remove the motherboard from the DVD player.
    • Remove the motherboard from the DVD player.
결론
Nathan Sarti
회원 가입일: 2018년 08월 31일
253 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 54
