주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Power cords can become easily broken or frayed, which can cause potential risks. This guide will teach you how to replace a damaged or broken power cord for the Philips DVP5992-F7.
부품
지정된 부품이 없습니다.
  1. Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver. Remove the 6.4 mm Phillips #1 screws on each side of the device. Remove the 6.4 mm Phillips #1 screws on each side of the device.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Remove the top plate of the DVD by firmly grasping the player on both sides. Shift the top plate towards the backside of the player.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Locate the  power cable connector inside the DVD player. Pinch down on both sides of the cable connector. Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
결론
Dyllon Phuong
회원 가입일: 2018년 08월 31일
447 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 194
