주요 콘텐츠로 건너뛰기
Philips DVP5992-F7 Tray Replacement
필요한 것
  1. Philips DVP5992-F7 Tray Replacement, Tray: 1 단계, 이미지 1/3 Philips DVP5992-F7 Tray Replacement, Tray: 1 단계, 이미지 2/3 Philips DVP5992-F7 Tray Replacement, Tray: 1 단계, 이미지 3/3
    • Plug in the DVD player.
    • Press the eject button to open the tray.
    • Push up on the tray faceplate to remove it.
  2. Philips DVP5992-F7 Tray Replacement: 2 단계, 이미지 1/2 Philips DVP5992-F7 Tray Replacement: 2 단계, 이미지 2/2
    • Press the eject button to re-insert the tray.
    • Unplug the DVD player after the tray is closed.
  3. Philips DVP5992-F7 Tray Replacement: 3 단계, 이미지 1/3 Philips DVP5992-F7 Tray Replacement: 3 단계, 이미지 2/3 Philips DVP5992-F7 Tray Replacement: 3 단계, 이미지 3/3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  4. Philips DVP5992-F7 Tray Replacement: 4 단계, 이미지 1/2 Philips DVP5992-F7 Tray Replacement: 4 단계, 이미지 2/2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  5. Philips DVP5992-F7 Tray Replacement: 5 단계, 이미지 1/3 Philips DVP5992-F7 Tray Replacement: 5 단계, 이미지 2/3 Philips DVP5992-F7 Tray Replacement: 5 단계, 이미지 3/3
    • Locate the motherboard within the DVD player.
    • Firmly grasp the ribbon wire and unplug it from the motherboard.
  6. Philips DVP5992-F7 Tray Replacement: 6 단계, 이미지 1/2 Philips DVP5992-F7 Tray Replacement: 6 단계, 이미지 2/2
    • Firmly grasp the bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the bundled cable connector from the motherboard.
  7. Philips DVP5992-F7 Tray Replacement: 7 단계, 이미지 1/2 Philips DVP5992-F7 Tray Replacement: 7 단계, 이미지 2/2
    • Firmly grasp the second bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the second bundled cable connector from the motherboard.
  8. Philips DVP5992-F7 Tray Replacement: 8 단계, 이미지 1/2 Philips DVP5992-F7 Tray Replacement: 8 단계, 이미지 2/2
    • Remove the 9.0 mm #1 Phillips head screw that holds the tray to the DVD player.
  9. Philips DVP5992-F7 Tray Replacement: 9 단계, 이미지 1/2 Philips DVP5992-F7 Tray Replacement: 9 단계, 이미지 2/2
    • Lift the tray out of the DVD player from the back.
결론
Dyllon Phuong
회원 가입일: 08/31/18
540 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 479
