주요 콘텐츠로 건너뛰기
Philips DVP5992-F7 USB port Replacement
필요한 것
  1. Philips DVP5992-F7 USB port Replacement, USB port: 1 단계, 이미지 1/3 Philips DVP5992-F7 USB port Replacement, USB port: 1 단계, 이미지 2/3 Philips DVP5992-F7 USB port Replacement, USB port: 1 단계, 이미지 3/3
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 USB port Replacement: 2 단계, 이미지 1/2 Philips DVP5992-F7 USB port Replacement: 2 단계, 이미지 2/2
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 USB port Replacement: 3 단계, 이미지 1/3 Philips DVP5992-F7 USB port Replacement: 3 단계, 이미지 2/3 Philips DVP5992-F7 USB port Replacement: 3 단계, 이미지 3/3
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
  4. Philips DVP5992-F7 USB port Replacement: 4 단계, 이미지 1/2 Philips DVP5992-F7 USB port Replacement: 4 단계, 이미지 2/2
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
  5. Philips DVP5992-F7 USB port Replacement: 5 단계, 이미지 1/2 Philips DVP5992-F7 USB port Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Sarti
회원 가입일: 08/31/18
274 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 520
