주요 콘텐츠로 건너뛰기
Philips Hue LightStrip Plus AC power adapter Replacement
필요한 것
  1. Philips Hue LightStrip Plus AC power adapter Replacement, Open Control Box: 1 단계, 이미지 2개 중 1개 Philips Hue LightStrip Plus AC power adapter Replacement, Open Control Box: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    TR7 Torx Security Screwdriver
    $5.99
    • Using a TR7 Torx Security Screwdriver, unscrew the two screws securing the lid to the base of the control box.
    • Using three iFixit Opening Picks, separate the lid from the slides of the control box.
    • Using a Spudger at the point where the cable enters the control box, lift off the lid.
  2. Philips Hue LightStrip Plus AC power adapter Replacement, Desolder power cable from circuit board: 2 단계, 이미지 3개 중 1개 Philips Hue LightStrip Plus AC power adapter Replacement, Desolder power cable from circuit board: 2 단계, 이미지 3개 중 2개 Philips Hue LightStrip Plus AC power adapter Replacement, Desolder power cable from circuit board: 2 단계, 이미지 3개 중 3개
    • Lift the circuit board out of the control box
    • Using your Soldering Skills, desolder the red and black cables from the circuit board.
  3. Philips Hue LightStrip Plus AC power adapter Replacement, Prepare new power cable: 3 단계, 이미지 3개 중 1개 Philips Hue LightStrip Plus AC power adapter Replacement, Prepare new power cable: 3 단계, 이미지 3개 중 2개 Philips Hue LightStrip Plus AC power adapter Replacement, Prepare new power cable: 3 단계, 이미지 3개 중 3개
    • Purchase a reputable AC Adapter rated at exactly 24V and at least 0.83A as per the specifications written on the original adapter. For example, the Mean Well GE24I24-P1J. As this is a universal adapter, you will also need to purchase the appropriate Mean Well AC Plug for your region.
    • Using safety glasses and a wire cutter, cut the barrel connector off the end of the new AC Adapter.
    • Using a wire stripper, expose 1cm of copper on the ends of the positive and negative wires.
  4. Philips Hue LightStrip Plus AC power adapter Replacement, Solder new power cable to circuit board: 4 단계, 이미지 3개 중 1개 Philips Hue LightStrip Plus AC power adapter Replacement, Solder new power cable to circuit board: 4 단계, 이미지 3개 중 2개 Philips Hue LightStrip Plus AC power adapter Replacement, Solder new power cable to circuit board: 4 단계, 이미지 3개 중 3개
    • Insert the positive wire, differentiated with faint dashes, into the hole marked VBUS and solder it in place.
    • Insert the negative wire, into the hole marked GND and solder it in place.
  5. Philips Hue LightStrip Plus AC power adapter Replacement, Reassemble the control box: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $5.99
    • Place the circuit board back into the control box, aligning it with the 3 white plastic poles.
    • Guide the power cable through the strain relief as shown.
    • Using a TR7 Torx Security Screwdriver, secure the lid back in place with the two screws.
결승점
작성자
1다른 기여자 명과 함께
Kris
회원 가입일: 05/25/23
217 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 76
전체 시간: 1,927
