주요 콘텐츠로 건너뛰기
Philips Norelco BG2040 BodyGroom 7100 Motor Replacement
필요한 것
  1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: 1 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: 1 단계, 이미지 2개 중 2개
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 2 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 2 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 3 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 3 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 4 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 5 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 5 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 6 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 7 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 7 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 7 단계, 이미지 3개 중 3개
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
  8. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: 8 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: 8 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: 8 단계, 이미지 3개 중 3개
    • *Please note that you do not need to remove the LED board from the battery pack for this guide. Begin the following steps after removal of the entire battery pack.*
    • Using the spudger, unclip the plastic housing around white casing.
    • Remove one half of the black housing first, and then proceed to the next half.
  9. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Once housing is removed, pull off shaver head. *Once black housing is removed this part may fall off*
  10. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 10 단계, 이미지 3개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 10 단계, 이미지 3개 중 2개 Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: 10 단계, 이미지 3개 중 3개
    • Use spudger to pry motor out of the white housing.
    • Pull waterproofing case off of the motor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
August Post
회원 가입일: 11/07/17
415 평판
안내서 3개를 작성함
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G4
3 회원들
안내서 7개를 작성함
댓글 한 개
Great guide. Thanks
Steve Riggle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 26
전체 시간: 2,689
