주요 콘텐츠로 건너뛰기
Philips Norelco BeardTrimmer 3100 Battery Replacement
필요한 것
  1. Philips Norelco BeardTrimmer 3100 Battery Replacement, Front and Back Panels: 1 단계, 이미지 1개 중 1개
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Battery Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Battery Replacement: 3 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Battery Replacement: 4 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 4 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Battery Replacement: 5 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 5 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Battery Replacement: 6 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Battery Replacement: 8 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 8 단계, 이미지 2개 중 2개
  9. Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: 9 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: 9 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Battery Replacement, Battery: 9 단계, 이미지 3개 중 3개
    • Face the battery towards you.
    • Locate the power connectors on the bottom of the trimmer, pull them from the base with your spudger.
  10. Philips Norelco BeardTrimmer 3100 Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Grab the battery by its sides, pull it upwards out of the base of the trimmer.
  11. Philips Norelco BeardTrimmer 3100 Battery Replacement: 11 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Locate the connection between the blue wire and the battery. Melt the solder and completely remove the battery.
    • Be careful when dealing with solder. The metals will become very hot and can cause damage to skin/clothing.
결론
다른 29명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Darren Chu
회원 가입일: 09/03/15
1,617 평판
안내서 3개를 작성함
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G2
4 회원들
안내서 14개를 작성함
댓글 20개
Hi, what are the specs on the NiMh battery?
Eric Nguyen - 답글
NiMh AA 1650 mAh 1.2V rechargeable battery. Search Amazon.com for philips norelco qt4022 battery. One result is UPC 737212062822
galligant -
I think you can simply use a AA battery, 1.2V
Olivier Lefaux - 답글
Note: AA Alkaline battery is 1.5V and not rechargeable.
galligant -
Awesome work.very helpful
Himanshu sahrma - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 36
지난 30일: 173
전체 시간: 72,898
