주요 콘텐츠로 건너뛰기
Philips Norelco BeardTrimmer 3100 Power Switch Replacement
필요한 것
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: 1 단계, 이미지 1/1
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 2 단계, 이미지 1/2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 2 단계, 이미지 2/2
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 3 단계, 이미지 1/2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 3 단계, 이미지 2/2
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 4 단계, 이미지 1/3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 4 단계, 이미지 2/3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 4 단계, 이미지 3/3
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 5 단계, 이미지 1/3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 5 단계, 이미지 2/3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 5 단계, 이미지 3/3
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 6 단계, 이미지 1/2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 6 단계, 이미지 2/2
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 7 단계, 이미지 1/1
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 8 단계, 이미지 1/2 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 8 단계, 이미지 2/2
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: 9 단계, 이미지 1/1
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 10 단계, 이미지 1/1
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 11 단계, 이미지 1/3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 11 단계, 이미지 2/3 Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 11 단계, 이미지 3/3
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: 12 단계, 이미지 1/1
    • Remove the power switch from the front panel once the white plastic frame is removed.
결론
Tamara Titus
회원 가입일: 09/03/15
133 평판
안내서 1개 작성함
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 41
전체 시간: 5,800
