주요 콘텐츠로 건너뛰기
Philips Norelco OneBlade Exterior Casing Replacement
필요한 것
  1. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: 1 단계, 이미지 3개 중 1개 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: 1 단계, 이미지 3개 중 2개 Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: 1 단계, 이미지 3개 중 3개
    • Ensure razor is off, and razor blade has been removed.
  2. Philips Norelco OneBlade Exterior Casing Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco OneBlade Exterior Casing Replacement: 2 단계, 이미지 2개 중 2개
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull top razor apart.
    • Caution, device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Exterior Casing Replacement: 3 단계, 이미지 1개 중 1개
    • Power button should face forward in same direction as circuit board. The crease on each casing component should line up.
결론
Please dispose of exterior casing properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
작성자
1다른 기여자 명과 함께
Joshua Etchberger
회원 가입일: 11/07/17
472 평판
안내서 3개를 작성함
IUPUI, Team S3-G3, Harley Fall 2017 IUPUI, Team S3-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G3
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 27
지난 30일: 71
전체 시간: 3,601
