주요 콘텐츠로 건너뛰기
Philips Norelco OneBlade Servo Motor Replacement
필요한 것
  1. Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 1 단계, 이미지 1/3 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 1 단계, 이미지 2/3 Philips Norelco OneBlade Servo Motor Replacement, Servo Motor: 1 단계, 이미지 3/3
    • Ensure razor is off and razor blade has been removed.
  2. Philips Norelco OneBlade Servo Motor Replacement: 2 단계, 이미지 1/2 Philips Norelco OneBlade Servo Motor Replacement: 2 단계, 이미지 2/2
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull casing apart.
    • Device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Servo Motor Replacement: 3 단계, 이미지 1/3 Philips Norelco OneBlade Servo Motor Replacement: 3 단계, 이미지 2/3 Philips Norelco OneBlade Servo Motor Replacement: 3 단계, 이미지 3/3
    • Locate wires below motor on either side of circuit board.
    • Remove solder from each joint using solder removal kit.
    • Do not attempt to remove wires by force.
  4. Philips Norelco OneBlade Servo Motor Replacement: 4 단계, 이미지 1/1
    • Remove new motor from package and place in position.
    • Motor should sit above circuit board with connection prongs facing downward. Additionally, center extrusion on bottom of motor should sit in provided hole.
결론
Please dispose of servo motor properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
다른 5명이 해당 안내서를 완성하였습니다.
Joshua Etchberger
회원 가입일: 11/07/17
472 평판
안내서 3개 작성하였습니다
IUPUI, Team S3-G3, Harley Fall 2017 IUPUI, Team S3-G3, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G3
3 회원들
안내서 3개 작성하였습니다
댓글 10개
does removing the motor exposing the battery? In my unit I see some green thing underneath the motor, looks like a AA battery, can you confirm?
or is it from somewhere else? (I need to replace my battery)
Yarden Cohen - 답글
I just dismantled my shaver, and it has a 1.2v AA size NiMH battery (suppo hsy aa1200).
João Paulo Gomes -
I’m also curious about the battery. Any one have pictures of it or know what kind of battery it has inside?
James Almeida - 답글
João Paulo Gomes -
Thanks! This definitely helps.
James Almeida -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 87
전체 시간: 19,252
