주요 콘텐츠로 건너뛰기
Philips PD9000 37 Buttons Replacement
필요한 것
  1. Philips PD9000 37 Buttons Replacement, Buttons: 1 단계, 이미지 1/1
    • Lay the player flat so the outside casing is facing upwards. Using the screwdriver, unscrew all the case screws on the bottom of the player.
  2. Philips PD9000 37 Buttons Replacement: 2 단계, 이미지 1/3 Philips PD9000 37 Buttons Replacement: 2 단계, 이미지 2/3 Philips PD9000 37 Buttons Replacement: 2 단계, 이미지 3/3
    • Open the disc flap and unscrew the screws inside. There will be three screws.
    • Using spudger, pry open the disk casing, and pull upwards removing it from the outer casing.
  3. Philips PD9000 37 Buttons Replacement: 3 단계, 이미지 1/3 Philips PD9000 37 Buttons Replacement: 3 단계, 이미지 2/3 Philips PD9000 37 Buttons Replacement: 3 단계, 이미지 3/3
    • After casing has been detached, there will be a wire connecting the button panel on the disk flap case to the motherboard.
    • To detach this wire, use your fingers and tightly pinch the plastic connector, and gently pull upwards disconnecting it from the motherboard.
  4. Philips PD9000 37 Buttons Replacement: 4 단계, 이미지 1/1
    • On the bottom side of the disk flap case, the back of the button panel will be visible. Using a Philips J0 screwdriver, unscrew all 6 screws.
  5. Philips PD9000 37 Buttons Replacement: 5 단계, 이미지 1/3 Philips PD9000 37 Buttons Replacement: 5 단계, 이미지 2/3 Philips PD9000 37 Buttons Replacement: 5 단계, 이미지 3/3
    • Once unscrewed. gently pull upwards detaching the button panel from the casing.
결론
Abigail Scarborough
회원 가입일: 09/28/15
193 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,733
