주요 콘텐츠로 건너뛰기
Philips PD9000 37 White Outer Housing Replacement
필요한 것
  1. Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: 1 단계, 이미지 1/3 Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: 1 단계, 이미지 2/3 Philips PD9000 37 White Outer Housing Replacement, White Outer Housing: 1 단계, 이미지 3/3
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
  2. Philips PD9000 37 White Outer Housing Replacement: 2 단계, 이미지 1/2 Philips PD9000 37 White Outer Housing Replacement: 2 단계, 이미지 2/2
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
  3. Philips PD9000 37 White Outer Housing Replacement: 3 단계, 이미지 1/3 Philips PD9000 37 White Outer Housing Replacement: 3 단계, 이미지 2/3 Philips PD9000 37 White Outer Housing Replacement: 3 단계, 이미지 3/3
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
  4. Philips PD9000 37 White Outer Housing Replacement: 4 단계, 이미지 1/3 Philips PD9000 37 White Outer Housing Replacement: 4 단계, 이미지 2/3 Philips PD9000 37 White Outer Housing Replacement: 4 단계, 이미지 3/3
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
결론
Julia Sheremet
회원 가입일: 09/28/15
303 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 466
