주요 콘텐츠로 건너뛰기
소개
There is this great teardown guide for Philips Steam Iron:
Philips Pressurised Steam Generator GC8220 Teardown
I want to clarify about its temperature sensor; that if faulty, it will make problems for the steam function.
If no Philips spare part is available to you, it can be replaced with a generic from electronics component shops.
  1. The Temperature Sensor is attached to the bottom of the Boiler unit.
    • The Temperature Sensor is attached to the bottom of the Boiler unit.
    • It is an NTC Thermistor.
  2. It is connected to the Main PCB.
    • It is connected to the Main PCB.
  3. It looks like a diode. But it is a resistor that changes value with temperature.
    • It looks like a diode. But it is a resistor that changes value with temperature.
  4. They come in a range of values. 10kOhms ~ 100 kOhms.
    • They come in a range of values. 10kOhms ~ 100 kOhms.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Omid
회원 가입일: 2017년 07월 23일
220 평판
안내서 1개 작성함
댓글 3개
With GC9640 the termistor is 226 kOhm @ 26°C.
Beim GC9640 hat der NTC 226 kOhm bei 26°C
John Maier - 답글
My Philips GC 9245 after ironing found water on the shirts, and the iron heat is not like as hot as in the past, is this cause by the Temperature Sensor (NTC Thermistor) ?
lylim_ly - 답글
With GC9220 model, résistance of boiler CTN : around 300k à 15°C, decreasing slowly to 160K at around 30°C, I didn’t test with other temperature.
Nico Land - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 60
전체 시간: 3,480
