주요 콘텐츠로 건너뛰기
Philips Respironics System One REMstar Circuit Board Replacement
필요한 것
  1. Philips Respironics System One REMstar Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1개 중 1개
    • Turn the device upside down so that the rubber feet are facing you.
    • Use a Torx TR15 screwdriver to remove the two 46.5mm screws located on the back.
    • Gently separate the panel so the wires are not damaged.
  2. Philips Respironics System One REMstar Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Lift out the inner casing.
  3. Philips Respironics System One REMstar Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the motor from the bottom portion of the casing and set it aside.
  4. Philips Respironics System One REMstar Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Philips Respironics System One REMstar Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the side panel by lifting it up out of the base.
    • Remove the grouped wire and wire connector.
  5. Philips Respironics System One REMstar Circuit Board Replacement: 5 단계, 이미지 2개 중 1개 Philips Respironics System One REMstar Circuit Board Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  6. Philips Respironics System One REMstar Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Philips Respironics System One REMstar Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the green, red, and white wire connectors from their connections on the circuit board.
결론
작성자
2다른 기여자 명과 함께
Rachel Ross
회원 가입일: 09/16/20
133 평판
안내서 1개를 작성함
2가이드 댓글
Do you happen to have a part number or link for replacement pcb?
Kyle Pierce - 답글
Ce anume nu funcționează ?
Mircea Crisan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 1,228
