소개
An 8-mm socket wrench with extension is required. For more information on replacing the oxygen valve, please refer to page 9-74 of the service manual.
필요한 것
Before replacing the oxygen valve assembly:
You must install the oxygen regulator assembly before reinstalling the oxygen valve assembly
When reinstalling the oxygen valve, make sure the oxygen regulator and oxygen flow sensor are fully installed to the oxygen valve assembly
Always inspect the O-rings between interconnecting parts, and replace them if they are visibly damaged or rough to the touch.
Always use new O-rings supplied with replacement parts
Lightly lubricate O-rings with Krytox GPL226 lubricant when installing, and relubricate at every reinstallation
