주요 콘텐츠로 건너뛰기
Philips Respironics V60 Air Inlet Filter Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
  1. Philips Respironics V60 Air Inlet Filter Replacement, shut down the ventilator: 1 단계, 이미지 1/2 Philips Respironics V60 Air Inlet Filter Replacement, shut down the ventilator: 1 단계, 이미지 2/2
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    • Disconnect the ventilator from the AC power.
  2. Philips Respironics V60 Air Inlet Filter Replacement, remove side panel: 3 단계, 이미지 1/1
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
  3. Philips Respironics V60 Air Inlet Filter Replacement, replace filter: 4 단계, 이미지 1/1
    • Remove the inlet filter by pinching it out of the recess in the bracket.
    • Install a new air filter by tucking it into the recessed area.
결론
  1. Place back the side panel.
  2. Connect the ventilator back to the AC power.
  3. Power on the ventilator with the ON/Shutdown key.
  4. Run the preoperational check.
다른 한 분이 해당 안내서를 완성하였습니다.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 31개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 44
전체 시간: 1,727
