주요 콘텐츠로 건너뛰기
Philips SBA1060 Circuit Board Replacement
필요한 것
  1. Philips SBA1060 Circuit Board Replacement, Battery Casing: 1 단계, 이미지 1/1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Circuit Board Replacement: 2 단계, 이미지 1/3 Philips SBA1060 Circuit Board Replacement: 2 단계, 이미지 2/3 Philips SBA1060 Circuit Board Replacement: 2 단계, 이미지 3/3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Circuit Board Replacement: 3 단계, 이미지 1/2 Philips SBA1060 Circuit Board Replacement: 3 단계, 이미지 2/2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Circuit Board Replacement, Circuit Board: 4 단계, 이미지 1/1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Remove the damaged circuit board from the device.
  5. Philips SBA1060 Circuit Board Replacement: 5 단계, 이미지 1/2 Philips SBA1060 Circuit Board Replacement: 5 단계, 이미지 2/2
    • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    • Reassemble the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
April Driscoll
회원 가입일: 10/21/13
321 평판
안내서 3개 작성하였습니다
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 회원
CLEM-BENSON-F13S14G4
3 회원들
안내서 4개 작성하였습니다
댓글 2개
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - 답글
Nice picture,it helps a lot in trouble shooting !
sergio - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,299
