주요 콘텐츠로 건너뛰기
Philips SBA1060 Speaker Replacement
필요한 것
  1. Philips SBA1060 Speaker Replacement, Battery Casing: 1 단계, 이미지 1/1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Speaker Replacement: 2 단계, 이미지 1/3 Philips SBA1060 Speaker Replacement: 2 단계, 이미지 2/3 Philips SBA1060 Speaker Replacement: 2 단계, 이미지 3/3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Speaker Replacement: 3 단계, 이미지 1/2 Philips SBA1060 Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Philips SBA1060 Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Remove the circuit board by unscrewing the two interior screws located on the circuit board.
    • Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
  5. Philips SBA1060 Speaker Replacement: 5 단계, 이미지 1/2 Philips SBA1060 Speaker Replacement: 5 단계, 이미지 2/2
    • Locate the speaker needing replacing.
    • Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
  6. Philips SBA1060 Speaker Replacement: 6 단계, 이미지 1/3 Philips SBA1060 Speaker Replacement: 6 단계, 이미지 2/3 Philips SBA1060 Speaker Replacement: 6 단계, 이미지 3/3
    • Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
  7. Philips SBA1060 Speaker Replacement: 7 단계, 이미지 1/2 Philips SBA1060 Speaker Replacement: 7 단계, 이미지 2/2
    • Using a non-conductive glue, carefully seal the speaker to the casing.
    • Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
    • Reassemble the device
결론
다른 한 분이 해당 안내서를 완성하였습니다.
April Driscoll
회원 가입일: 10/21/13
321 평판
안내서 3개 작성하였습니다
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 회원
CLEM-BENSON-F13S14G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 19
전체 시간: 1,704
