주요 콘텐츠로 건너뛰기
Philips Satinelle Motor Replacement
필요한 것
  1. Philips Satinelle Motor Replacement, Plastic Cover: 1 단계, 이미지 1/3 Philips Satinelle Motor Replacement, Plastic Cover: 1 단계, 이미지 2/3 Philips Satinelle Motor Replacement, Plastic Cover: 1 단계, 이미지 3/3
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Motor Replacement: 2 단계, 이미지 1/2 Philips Satinelle Motor Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Motor Replacement: 3 단계, 이미지 1/1
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
  4. Philips Satinelle Motor Replacement, Motor: 4 단계, 이미지 1/2 Philips Satinelle Motor Replacement, Motor: 4 단계, 이미지 2/2
    • Remove the components.
  5. Philips Satinelle Motor Replacement: 5 단계, 이미지 1/3 Philips Satinelle Motor Replacement: 5 단계, 이미지 2/3 Philips Satinelle Motor Replacement: 5 단계, 이미지 3/3
    • Hold the motor with the gears face away from you.
    • Gently push the motor out with your thumbs.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Madeline Casalino
회원 가입일: 10/08/18
313 평판
안내서 3개 작성하였습니다
Marist, Team S1-G1, Chaterdon Fall 2018 Marist, Team S1-G1, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 2개
i dont know what i am doing wrong but it is not openning
Aj Queen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 24
전체 시간: 1,928
