주요 콘텐츠로 건너뛰기
Philips Satinelle Tension Clip Replacement
필요한 것
  1. Philips Satinelle Tension Clip Replacement, Tension Clip Replacement: 1 단계, 이미지 1/1
    • Remove Tweezer Head by pushing to the left with thumb.
  2. Philips Satinelle Tension Clip Replacement: 2 단계, 이미지 1/3 Philips Satinelle Tension Clip Replacement: 2 단계, 이미지 2/3 Philips Satinelle Tension Clip Replacement: 2 단계, 이미지 3/3
    • Locate the Tension Clip on the removable tweezer head.
    • Begin prying from the right side of the Tension Clip.
    • Finish removal by prying the left side of the Tension Clip.
  3. Philips Satinelle Tension Clip Replacement: 3 단계, 이미지 1/3 Philips Satinelle Tension Clip Replacement: 3 단계, 이미지 2/3 Philips Satinelle Tension Clip Replacement: 3 단계, 이미지 3/3
    • Replace the Tension Clip
    • Insert left side of clip roughly half way in.
    • Insert right side of clip and push both sides down with thumbs.
  4. Philips Satinelle Tension Clip Replacement: 4 단계, 이미지 1/2 Philips Satinelle Tension Clip Replacement: 4 단계, 이미지 2/2
    • Use Opening Tool to fully depress Tension Clip in place.
결론
Contact the manufacturer for a replacement Tension Clip.
George Tipker IV
회원 가입일: 11/11/17
148 평판
안내서 1개 작성함
IUPUI, Team S5-G5, Wilson Fall 2017 IUPUI, Team S5-G5, Wilson Fall 2017 회원
IUPUI-WILSON-F17S5G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 891
