주요 콘텐츠로 건너뛰기
Philips Somneo LED Assembly Replacement
필요한 것
  1. Philips Somneo LED Assembly Replacement, Antenna: 1 단계, 이미지 1개 중 1개
    • Remove the four silicone feet on the bottom plate.
    • Remove the following Phillips screws from the bottom plate:
    • Two 9 mm screws
    • Two 13 mm screws
  2. Philips Somneo LED Assembly Replacement: 2 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the bottom plate from the device.
  3. Philips Somneo LED Assembly Replacement: 3 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the antenna connector by pulling it directly out of its port.
    • Remove the antenna.
  4. Philips Somneo LED Assembly Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Remove the four 9 mm Phillips screws securing the motherboard.
  5. Philips Somneo LED Assembly Replacement: 5 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull the motherboard down until the cables are visible.
    • Take care not to strain the connected cables.
  6. Philips Somneo LED Assembly Replacement: 6 단계, 이미지 3개 중 1개 Philips Somneo LED Assembly Replacement: 6 단계, 이미지 3개 중 2개 Philips Somneo LED Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Remove each cord by gently disconnecting each connector with your hand.
  7. Philips Somneo LED Assembly Replacement: 7 단계, 이미지 3개 중 1개 Philips Somneo LED Assembly Replacement: 7 단계, 이미지 3개 중 2개 Philips Somneo LED Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Continue gently removing each cord with you hand.
  8. Philips Somneo LED Assembly Replacement: 8 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
  9. Philips Somneo LED Assembly Replacement, LED Assembly: 9 단계, 이미지 3개 중 1개 Philips Somneo LED Assembly Replacement, LED Assembly: 9 단계, 이미지 3개 중 2개 Philips Somneo LED Assembly Replacement, LED Assembly: 9 단계, 이미지 3개 중 3개
    • Use an opening pick to pry underneath the plastic covering the edges of the screen.
    • Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
  10. Philips Somneo LED Assembly Replacement: 10 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • The panel should be loosened significantly enough to be pulled off the main body, revealing the edges of the screen.
  11. Philips Somneo LED Assembly Replacement: 11 단계, 이미지 2개 중 1개 Philips Somneo LED Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the two 13 mm Phillips #0 screws on the bottom edges of the screen.
    • Remove the 9 mm Phillips #0 screws on the upper edge of the screen.
  12. Philips Somneo LED Assembly Replacement: 12 단계, 이미지 3개 중 1개 Philips Somneo LED Assembly Replacement: 12 단계, 이미지 3개 중 2개 Philips Somneo LED Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the display assembly.
  13. Philips Somneo LED Assembly Replacement: 13 단계, 이미지 3개 중 1개 Philips Somneo LED Assembly Replacement: 13 단계, 이미지 3개 중 2개 Philips Somneo LED Assembly Replacement: 13 단계, 이미지 3개 중 3개
    • On the back of the screen, remove the four 9 mm Phillips #00 screws, disconnecting the LED assembly.
  14. Philips Somneo LED Assembly Replacement: 14 단계, 이미지 3개 중 1개 Philips Somneo LED Assembly Replacement: 14 단계, 이미지 3개 중 2개 Philips Somneo LED Assembly Replacement: 14 단계, 이미지 3개 중 3개
    • Two cables connected to the LED were once connected to the motherboard, but are still attached to the body. They are threaded through black ovals connected to the body by a hard black adhesive.
    • Using a metal spudger, scrape underneath this adhesive and pry up, freeing the cable from the body. Repeat this for the other cable to free the LED.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan Borges
회원 가입일: 03/21/25
213 평판
안내서 1개를 작성함
UMass Dartmouth, Team 6-1, Botvin Spring 2025 UMass Dartmouth, Team 6-1, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S6G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 98
