주요 콘텐츠로 건너뛰기
Philips Sonicare DiamondClean Battery Replacement
필요한 것
  1. Philips Sonicare DiamondClean Battery Replacement, Case Replacement: 1 단계, 이미지 1/2 Philips Sonicare DiamondClean Battery Replacement, Case Replacement: 1 단계, 이미지 2/2
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Battery Replacement: 2 단계, 이미지 1/2 Philips Sonicare DiamondClean Battery Replacement: 2 단계, 이미지 2/2
    • Use a nylon spudger to pry the chrome cap at the bottom off.
  3. Philips Sonicare DiamondClean Battery Replacement: 3 단계, 이미지 1/1
    • Use a nylon spudger to release the black tabs on either side of internals.
  4. Philips Sonicare DiamondClean Battery Replacement: 4 단계, 이미지 1/2 Philips Sonicare DiamondClean Battery Replacement: 4 단계, 이미지 2/2
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Remove rubber covers from the top of the motherboard and the back of the battery.
  6. Philips Sonicare DiamondClean Battery Replacement: 6 단계, 이미지 1/1
    • Using a soldering iron, remove the solder from the three marked spots.
    • The pins are labeled "F1", "R6", "JP1"
  7. Philips Sonicare DiamondClean Battery Replacement: 7 단계, 이미지 1/1
    • After de-soldering, the battery should be loose. If this is not the case, spend more time removing the solder.
    • When the battery comes loose, gently wiggle it out and away from the device.
  8. Philips Sonicare DiamondClean Battery Replacement: 8 단계, 이미지 1/1
    • Carefully reinsert the new battery into the same spot as the old one. Gently press until it is firmly pressed against the toothbrush.
    • Green batteries have a black horizontal stripe at the top on the green wrap. That is the positive terminal that goes towards the top of the unit
  9. Philips Sonicare DiamondClean Battery Replacement: 10 단계, 이미지 1/1
    • Apply a small amount of solder to the three points shown to attach the battery.
  10. Philips Sonicare DiamondClean Battery Replacement: 11 단계, 이미지 1/1
    • Replace the rubber covers on the motherboard and battery.
    • Reverse the case replacement guide to finish putting the toothbrush back together.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Zachary Bertrand
회원 가입일: 11/20/17
843 평판
안내서 3개 작성하였습니다
IUPUI, Team S22-G1, Bayer Fall 2017 IUPUI, Team S22-G1, Bayer Fall 2017 회원
IUPUI-BAYER-F17S22G1
4 회원들
안내서 9개 작성하였습니다
댓글 3개
I recommend to soak the bottom of the brush in a cup of warm water to make it easier to remove the bottom cap. The plastic is very easy to crack when cold.
Janson McCreery - 답글
This is a decent guide. Thank you to the author! Problem is that they don't make these devices user serviceable, so we basically have to pry and force the cap off. ARGH! RIGHT TO REPAIR NOW!!
Maybe Dave - 답글
Die Anleitung ist bei Schrit 6 etwas irreführend, es sind nur 2 Lötstellen, die Batterie hat ja auch nur 2 Lötfahnen wie man sieht. Eine bei F1, die andere bei R6 und JP1. Der unterste Pfeil im Bild der auf JP1 zeigt ist falsch. Ich empfehle das Lötzinn mit einer Entlötpumpe mit Silikonspitze komplett zu entfernen da die Batterie in einer Kunststofffassung fest eingeklemmt ist und nur durch erhitzen des Lötzinns schwer herauszubekommen ist und sich direkt neben der unteren Lötstelle auch ein IC befindet sollte man beim löten sehr vorsichtig sein.
Michael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 28
7일 전: 175
30일 전: 773
전체 시간: 55,483
