주요 콘텐츠로 건너뛰기
Philips Sonicare DiamondClean Metal Brush Connector Replacement
필요한 것
  1. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: 1 단계, 이미지 2개 중 1개 Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: 1 단계, 이미지 2개 중 2개
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 2 단계, 이미지 2개 중 1개 Philips Sonicare DiamondClean Metal Brush Connector Replacement: 2 단계, 이미지 2개 중 2개
    • Use a nylon spudger to pry the chrome cap at the bottom off.
  3. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Use a nylon spudger to release the black tabs on either side of internals.
  4. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 4 단계, 이미지 2개 중 1개 Philips Sonicare DiamondClean Metal Brush Connector Replacement: 4 단계, 이미지 2개 중 2개
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Metal Brush Connector Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the screw at the base of the metal head.
  6. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use fine tip tweezers to push the white plastic tabs in to release the head from the innards.
  7. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 7 단계, 이미지 1개 중 1개
    • Gently pull the metal head from the innards.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Zachary Bertrand
회원 가입일: 11/20/17
875 평판
안내서 3개를 작성함
IUPUI, Team S22-G1, Bayer Fall 2017 IUPUI, Team S22-G1, Bayer Fall 2017 회원
IUPUI-BAYER-F17S22G1
4 회원들
안내서 9개를 작성함
댓글 8개
Great guide - but where is a good source for replacement parts?
Christian Zischek - 답글
Ordered replacement part, came within 3 days at ebay. Didn’t have to replace the soft rubber inlet parts, only the connector.
Piece of cake, exchange of battery seems more labourous, but the brush still works for two weeks, so we postpone this job.
Emilio - 답글
Gut beschrieben, aber wo bekomme ich eine neue Antriebsachse?
Beste Grüße - pechi606
Walter P - 답글
Z.B. direkt aus China : ebay
VauWeh -
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
tim belina - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 69
지난 30일: 237
전체 시간: 20,670
