주요 콘텐츠로 건너뛰기
Philips Sonicare Essence 1 Series Front Handle Panel Replacement
필요한 것
  1. Philips Sonicare Essence 1 Series Front Handle Panel Replacement, Brush Head: 1 단계, 이미지 1/1
    • Place one hand on the toothbrush handle and one on the toothbrush head.
  2. Philips Sonicare Essence 1 Series Front Handle Panel Replacement: 2 단계, 이미지 1/1
    • Separate the toothbrush head from the body by twisting it in a counter-clockwise direction.
  3. Philips Sonicare Essence 1 Series Front Handle Panel Replacement, Front Handle Panel: 3 단계, 이미지 1/1
    • Insert the spudger along the seem at the top of the panel.
    • Begin to pry open the panel.
  4. Philips Sonicare Essence 1 Series Front Handle Panel Replacement: 4 단계, 이미지 1/1
    • Insert the plastic pick at the top of the seam that has already been slightly pried open.
    • Continue down the seam, prying the rest of the panel open with the spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Samantha Miller
회원 가입일: 11/07/17
140 평판
안내서 1개 작성함
IUPUI, Team S7-G1, Baechle Fall 2017 IUPUI, Team S7-G1, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S7G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 1,085
