소개
Here is how to replace the brush head on the Philips Sonicare FlexCare. This should be done when the blue reminder bristles fade to white or at least every three months. This is to prevent bacteria buildup and to maintain effectiveness. Dull bristles may leave plaque buildup. This is an easy repair. Before starting, ensure buildup between the head and body is removed. This can be done using rubbing alcohol and a Q-tip. Replacement heads can be found almost anywhere that sells Philips products including the Philips website, Amazon, and Walmart.
다른 2명이 해당 안내서를 완성하였습니다.
