주요 콘텐츠로 건너뛰기
Philips Sonicare FlexCare Shaft Replacement
필요한 것
  1. Philips Sonicare FlexCare Shaft Replacement, Shaft: 1 단계, 이미지 1/1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Shaft Replacement: 2 단계, 이미지 1/1
    • Have a look to an alternative opening procedure.
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
  3. Philips Sonicare FlexCare Shaft Replacement: 3 단계, 이미지 1/2 Philips Sonicare FlexCare Shaft Replacement: 3 단계, 이미지 2/2
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Philips Sonicare FlexCare Shaft Replacement: 4 단계, 이미지 1/1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Shaft Replacement: 5 단계, 이미지 1/1
    • Using a #00 phillips head screwdriver, loosen the screw completely.
  6. Philips Sonicare FlexCare Shaft Replacement: 6 단계, 이미지 1/1
    • Rotate the interior of the toothbrush until the screw is facing downward. Slightly shake the interior so that the screw with its accompanying metal part fall out.
    • Slightly shake the interior so that the screw falls out.
    • A small ring may fall out when the screw is removed. Be careful not to lose the ring.
  7. Philips Sonicare FlexCare Shaft Replacement: 7 단계, 이미지 1/1
    • Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
    • A small nut may fall out when the shaft is removed. Be careful not to lose the nut.
  8. Philips Sonicare FlexCare Shaft Replacement: 8 단계, 이미지 1/1
    • Once the shaft is released, separate it from the body of the interior.
    • Insert the replacement shaft by aligning the the components and applying a force to insert the legs (one of the legs is identified by the red arrow) of the shaft into the interior.
결론
다른 47명이 해당 안내서를 완성하였습니다.
Tasha Panattoni
회원 가입일: 04/14/15
774 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015 회원
CPSU-MANESS-S15S4G6
4 회원들
안내서 23개 작성하였습니다
댓글 37개
Where do you get a replacement shaft? I can't find any online
noahmckinnon - 답글
You don't need to pry the bottom plate off and risk damaging the seal. Simply apply firm pressure on the shaft against a table while simultaneously wiggling the bottom plate back and forth with a large flathead screwdriver inserted into the charging hole on the bottom. It will pop off smoothly leaving the seal untouched and not scratching the housing or charging plug.
jelneutron3 - 답글
I can not find the shaft anywhere who sells them
bennie - 답글
Like the previous comments I also am looking for the replacement shaft. If anyone has found a source please leave a comment with regards to where they can be found.
Thanks for the help
Lino Valadas - 답글
Like everyone above, I can't locate the "replacement shaft". Anyone have any ideas who might have one? A $179 toothbrush should last more than the one year warranty! Is the Braun Oral-B any better?
pgootos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 140
7일 전: 984
30일 전: 4,087
전체 시간: 238,184
