이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
Rotate the interior of the toothbrush until the screw is facing downward. Slightly shake the interior so that the screw with its accompanying metal part fall out.
Slightly shake the interior so that the screw falls out.
Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
Once the shaft is released, separate it from the body of the interior.
Insert the replacement shaft by aligning the the components and applying a force to insert the legs (one of the legs is identified by the red arrow) of the shaft into the interior.
다른 47명이 해당 안내서를 완성하였습니다.
댓글 37개
Where do you get a replacement shaft? I can't find any online
You don't need to pry the bottom plate off and risk damaging the seal. Simply apply firm pressure on the shaft against a table while simultaneously wiggling the bottom plate back and forth with a large flathead screwdriver inserted into the charging hole on the bottom. It will pop off smoothly leaving the seal untouched and not scratching the housing or charging plug.
Like the previous comments I also am looking for the replacement shaft. If anyone has found a source please leave a comment with regards to where they can be found.
Thanks for the help
