주요 콘텐츠로 건너뛰기
Philips Sonicare FlexCare Spring Replacement
필요한 것
  1. Philips Sonicare FlexCare Spring Replacement, Spring: 1 단계, 이미지 1/1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Spring Replacement: 2 단계, 이미지 1/2 Philips Sonicare FlexCare Spring Replacement: 2 단계, 이미지 2/2
    • Push the flat edge of a nylon or metal spudger between the seal and the toothbrush body and pry it up. Do this on each side until the seal is partially sticking out on all sides.
  3. Philips Sonicare FlexCare Spring Replacement: 3 단계, 이미지 1/1
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the interior electronics are exposed.
  4. Philips Sonicare FlexCare Spring Replacement: 4 단계, 이미지 1/1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Spring Replacement: 5 단계, 이미지 1/1
    • Pull off the black rubber ring with a metal or nylon spudger until it clears the metal piece that holds it in place. Pull the ring out.
  6. Philips Sonicare FlexCare Spring Replacement: 6 단계, 이미지 1/1
    • Remove the spring from the rubber ring and replace it with the new spring.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joanna Moraza
회원 가입일: 04/14/15
1,765 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015 회원
CPSU-MANESS-S15S4G6
4 회원들
안내서 23개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 69
전체 시간: 5,011
