주요 콘텐츠로 건너뛰기
Philips Sonicare FlexCare UV Light Bulb Replacement
  1. Philips Sonicare FlexCare UV Light Bulb Replacement, UV Light Bulb: 1 단계, 이미지 1개 중 1개
    • Before initiating the process, ensure that the sanitizer is not plugged into an outlet. Swing the door open to expose the interior of the sanitizing device.
  2. Philips Sonicare FlexCare UV Light Bulb Replacement: 2 단계, 이미지 1개 중 1개
    • Grip the sides of the plastic cover that is shielding the circuitry. Pull the cover outward to remove it from the sanitizer.
  3. Philips Sonicare FlexCare UV Light Bulb Replacement: 3 단계, 이미지 2개 중 1개 Philips Sonicare FlexCare UV Light Bulb Replacement: 3 단계, 이미지 2개 중 2개
    • Squeeze the sides of the guard that is placed over the UV light bulb. Pull the piece outward to remove it.
  4. Philips Sonicare FlexCare UV Light Bulb Replacement: 4 단계, 이미지 2개 중 1개 Philips Sonicare FlexCare UV Light Bulb Replacement: 4 단계, 이미지 2개 중 2개
    • Before holding the light bulb, ensure that it is not warm due to previous use. Once that is confirmed, take a hold of the light bulb by the threaded surface and rotate it while pulling it outward. Have a compatible UV bulb to replace the old one.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tasha Panattoni
회원 가입일: 04/14/15
798 평판
안내서 2개를 작성함
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015 회원
CPSU-MANESS-S15S4G6
4 회원들
안내서 23개를 작성함
6가이드 댓글
I’ve had mines less than a year. The uv lamp makes a “whizz sound for a second and then stops. No noise. No light. Does the bulb needs to be replaced ? Is it normal for it to die in 9 mths?
Uroos ali - 답글
I’ve had my unit for over 7 years, I was getting ready to replace it. Thanks so much, I’m not a handy person and I’m really pleased to see that I could fix this problem with your helpful advice!
roleplay1 - 답글
Just changed the bulb and it still does not work :( :( :(
nicoleproulx47 - 답글
Do UV bulbs need changing on a yearly basis or are they still good if giving out light?
jujsf - 답글
I've had mine for close to 10 years I'm just now having to change my UV bulb
Christopher Hurtle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 25
지난 30일: 103
전체 시간: 12,702
