주요 콘텐츠로 건너뛰기
Philips Sonicare HX6710 Replacing the Battery
필요한 것
  1. Philips Sonicare HX6710 Replacing the Battery, Open housing: 1 단계, 이미지 1/3 Philips Sonicare HX6710 Replacing the Battery, Open housing: 1 단계, 이미지 2/3 Philips Sonicare HX6710 Replacing the Battery, Open housing: 1 단계, 이미지 3/3
  2. Philips Sonicare HX6710 Replacing the Battery, Remove lower cap: 2 단계, 이미지 1/2 Philips Sonicare HX6710 Replacing the Battery, Remove lower cap: 2 단계, 이미지 2/2
    • Remove lower cap (2 plastic tabs). O-ring is already removed in this picture.
    • Here are the solder connections of the battery: + (red) and - (yellow).
  3. Philips Sonicare HX6710 Replacing the Battery, Replace the battery: 3 단계, 이미지 1/2 Philips Sonicare HX6710 Replacing the Battery, Replace the battery: 3 단계, 이미지 2/2
    • Unwrap the battery and replace it (see Soldering Skills).
    • To avoid a short circuit (the battery will normally still have a remaining charge), start at the positive pole of the battery and unsolder completely from the board.
    • Continue with the negative pole.
    • At the end, loosen the soldering pads from remaining solder, so that the contacts of the new battery can be inserted into the board.
    • Solder teh positive and negative pole.
    • Requires a 3.7V battery, which is approximately 14mm x 49mm (similar to AA).
  4. Philips Sonicare HX6710 Replacing the Battery, controls: 4 단계, 이미지 1/2 Philips Sonicare HX6710 Replacing the Battery, controls: 4 단계, 이미지 2/2
    • Before assembly, check the upper seal and the lower O-ring and replace those if necessary.
결론
다른 4명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Michael S.
회원 가입일: 12/10/17
636 평판
안내서 4개 작성하였습니다
댓글 한 개
I saw in another guide that it is advisable, before working on the Li-Ion battery, to break the join between the two pads of JP1 which disconnects the battery.
This is very important due to the volatile nature of Lithium-Ion batteries.
It also takes away some risk of shorting out the battery when we remove it.
So with the solder, before working, break the join between the two pads of JP1.
And at the end, after replaced the battery, re-join the two solder pads of JP1.
Albyee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 32
30일 전: 105
전체 시간: 6,046
