소개
This guide contains step-by-step instructions to replace power cord of the Philps steam Iron GC 1905.
If your Philips steam Iron GC 1905 does not switch on and the soleplate stays cold, it could indicate a connection problem and a possible fault in the power cord. Check the power cord regularly and if you notice that it’s distorted, twisted and shows visible damage or the plug is damaged, use this guide to replace the power cord.
A damaged power cord can cause the iron to malfunction and can be a safety hazard. Always use manufacturer certified heat-resistant power cord.
Before using this guide, check and make sure that the wall socket is functional and not causing connection problems. Sometimes, plugging the iron in an alternate wall socket can resolve the problem.
Power cord replacement is a simple repair. We encourage you to definitely try this at home because “The World Needs Fixers”.
Note: Do not throw away the discarded power cord with normal household waste. Hand it in collection point for recycling and help preserve the environment.
필요한 것
Switch off and unplug the iron. Drain the water from the water tank.
Grip the green cable as close to the crimp connector as possible.
For easy removal, pinch the crimp connector between your thumb and forefinger. Apply force to the connector rather than the cable.
Slide out the crimp connector attached to the cable.
Repeat the previous step to remove the red and black cables and take out the power cord.
Happy Fixing!
Happy Fixing!
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
het l'ange deksel was al door mij losgemaakt
2 klips in het midden ...kon niet verder Los krijgen
wat moet ik verser doen zonder stukken te maken stroomdraad is stuk ????
But where do I find new wire online
