주요 콘텐츠로 건너뛰기
Philips TAS7505 Motherboard Replacement
필요한 것
  1. Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: 1 단계, 이미지 1/2 Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: 1 단계, 이미지 2/2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 Motherboard Replacement: 2 단계, 이미지 1/3 Philips TAS7505 Motherboard Replacement: 2 단계, 이미지 2/3 Philips TAS7505 Motherboard Replacement: 2 단계, 이미지 3/3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 Motherboard Replacement: 3 단계, 이미지 1/3 Philips TAS7505 Motherboard Replacement: 3 단계, 이미지 2/3 Philips TAS7505 Motherboard Replacement: 3 단계, 이미지 3/3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Motherboard Replacement: 4 단계, 이미지 1/3 Philips TAS7505 Motherboard Replacement: 4 단계, 이미지 2/3 Philips TAS7505 Motherboard Replacement: 4 단계, 이미지 3/3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 Motherboard Replacement: 5 단계, 이미지 1/1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 Philips TAS7505 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 Philips TAS7505 Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Disconnect the battery from the motherboard by unclipping it from the side not visible to you
    • If you are having difficulties disconnecting the battery you can pull the battery out whole in order to get a better angle to disconnect it
  7. Philips TAS7505 Motherboard Replacement: 7 단계, 이미지 1/1
    • Pull out the motherboard then disconnect the USB-A & USB-C port by pressing the clip
  8. Philips TAS7505 Motherboard Replacement: 8 단계, 이미지 1/2 Philips TAS7505 Motherboard Replacement: 8 단계, 이미지 2/2
    • Next is to disconnect the speaker
    • pull the motherboard out as much as you can and then wiggle the white box back and forth to get it out
  9. Philips TAS7505 Motherboard Replacement: 9 단계, 이미지 1/2 Philips TAS7505 Motherboard Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Simply remove this white strand with a pair of tweezers.
  10. Philips TAS7505 Motherboard Replacement: 10 단계, 이미지 1/2 Philips TAS7505 Motherboard Replacement: 10 단계, 이미지 2/2
    • This is how the motherboard should be after doing all the steps correctly.
결론
Alejandro
회원 가입일: 09/26/22
121 평판
안내서 1개 작성함
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G2
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
The guides are very detailed with many steps and are easy to follow. It looks professional and well-made. Thank you for your contribution to Ifixit!
Dat Nguyen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 19
전체 시간: 281
