주요 콘텐츠로 건너뛰기
Philips TAS7505 Speaker Replacement
필요한 것
  1. Philips TAS7505 Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 1개 Philips TAS7505 Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 2개 Philips TAS7505 Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • Using the opening tool, remove the rubber padding from the bottom of the speaker.
    • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
  2. Philips TAS7505 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Philips TAS7505 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Philips TAS7505 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
    • Use the same opening tool from the previous step to remove the plastic plate.
  3. Philips TAS7505 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Philips TAS7505 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Philips TAS7505 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Speaker Replacement: 4 단계, 이미지 3개 중 1개 Philips TAS7505 Speaker Replacement: 4 단계, 이미지 3개 중 2개 Philips TAS7505 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
    • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
  5. Philips TAS7505 Speaker Replacement: 5 단계, 이미지 3개 중 1개 Philips TAS7505 Speaker Replacement: 5 단계, 이미지 3개 중 2개 Philips TAS7505 Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Find the rubber flap that covers the USB-A and USB-C port
    • Pull on the rubber flap, it should come out whole as shown in the second image
    • Once taken out the rubber flap, pull the interior of the speaker
  6. Philips TAS7505 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Philips TAS7505 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Once you have the speaker body out, unscrew the four screws holding the speaker down
    • Use Philips screwdriver head #0
  7. Philips TAS7505 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
    • See the motherboard repair guide for more in-depth instructions on this part
  8. Philips TAS7505 Speaker Replacement: 8 단계, 이미지 3개 중 1개 Philips TAS7505 Speaker Replacement: 8 단계, 이미지 3개 중 2개 Philips TAS7505 Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • The speaker will look like this if you have followed the steps correctly
결론
작성자
5다른 기여자 명과 함께
Frederick Jimenez
회원 가입일: 09/26/22
277 평판
안내서 2개를 작성함
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G2
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 34
전체 시간: 882
