주요 콘텐츠로 건너뛰기
Philips TAS7505 USB-A & USB-C port Replacement
필요한 것
  1. Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: 1 단계, 이미지 2개 중 1개 Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: 1 단계, 이미지 2개 중 2개
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 USB-A & USB-C port Replacement: 2 단계, 이미지 3개 중 1개 Philips TAS7505 USB-A & USB-C port Replacement: 2 단계, 이미지 3개 중 2개 Philips TAS7505 USB-A & USB-C port Replacement: 2 단계, 이미지 3개 중 3개
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 USB-A & USB-C port Replacement: 3 단계, 이미지 3개 중 1개 Philips TAS7505 USB-A & USB-C port Replacement: 3 단계, 이미지 3개 중 2개 Philips TAS7505 USB-A & USB-C port Replacement: 3 단계, 이미지 3개 중 3개
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 USB-A & USB-C port Replacement: 4 단계, 이미지 3개 중 1개 Philips TAS7505 USB-A & USB-C port Replacement: 4 단계, 이미지 3개 중 2개 Philips TAS7505 USB-A & USB-C port Replacement: 4 단계, 이미지 3개 중 3개
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 USB-A & USB-C port Replacement: 5 단계, 이미지 1개 중 1개
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 USB-A & USB-C port Replacement, USB-A & USB-C port: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #0 Screwdriver to remove all 6 screws.
  7. Philips TAS7505 USB-A & USB-C port Replacement: 7 단계, 이미지 1개 중 1개
    • Before pulling the USB port box out, disconnected the power connector from the motherboard.
    • Carefully pull out the USB port box
결론
작성자
3다른 기여자 명과 함께
Yamilena Hernandez
회원 가입일: 09/26/22
135 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G2
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 205
