주요 콘텐츠로 건너뛰기
Philips Wake-Up HF3531/01 Disassembly
필요한 것
  1. Philips Wake-Up HF3531/01 Disassembly, Start: 1 단계, 이미지 1/2 Philips Wake-Up HF3531/01 Disassembly, Start: 1 단계, 이미지 2/2
    • There is a screw under the shiny UL sticker. Remove the sticker and screw to remove this bottom panel.
    • There are two tabs holding the panel into the clock/light, so you might have to wiggle the panel forward and out to remove it.
  2. Philips Wake-Up HF3531/01 Disassembly, Prying open: 2 단계, 이미지 1/2 Philips Wake-Up HF3531/01 Disassembly, Prying open: 2 단계, 이미지 2/2
    • Flipping the light upside down will present a small section of the bezel that can be pried upward. It is a small plastic strip with hooks that have to be disengaged to be removed.
  3. Philips Wake-Up HF3531/01 Disassembly, Remove the button ring: 3 단계, 이미지 1/3 Philips Wake-Up HF3531/01 Disassembly, Remove the button ring: 3 단계, 이미지 2/3 Philips Wake-Up HF3531/01 Disassembly, Remove the button ring: 3 단계, 이미지 3/3
    • We can finally unscrew two more Philips head screws to remove the button ring.
  4. Philips Wake-Up HF3531/01 Disassembly, Front screen shield: 4 단계, 이미지 1/1
    • Now the screws holding the front screen shield need to be removed and the shield can be pulled away to the front.
    • Screw organization note for later: these screws have pointed ends
    • Take care not to damage the internal screen.
    • Unscrew the four screws holding the inner screen assembly in place.
  5. Philips Wake-Up HF3531/01 Disassembly, Inner screen assembly: 5 단계, 이미지 1/2 Philips Wake-Up HF3531/01 Disassembly, Inner screen assembly: 5 단계, 이미지 2/2
    • The inner screen assembly can be pulled out slightly to reveal tabs on each side that hold the assembly in.
    • Pry the back tabs inwards to release.
  6. Philips Wake-Up HF3531/01 Disassembly, Remove the screen: 6 단계, 이미지 1/3 Philips Wake-Up HF3531/01 Disassembly, Remove the screen: 6 단계, 이미지 2/3 Philips Wake-Up HF3531/01 Disassembly, Remove the screen: 6 단계, 이미지 3/3
    • The screen is connected to the plastic domed back with holes. There are two screws at the back of the base of this domed panel. Remove screws to remove screen.
    • Set screen panel aside for safe keeping.
    • More to see and modify...
결승점
다른 41명이 해당 안내서를 완성하였습니다.
Max
회원 가입일: 11/13/12
1,295 평판
안내서 1개 작성함
댓글 13개
Awesome teardown except for one little thing…
The factory sticker shows this is a 3530 which may not be different from a 3520. However, the bottom plate screw MUST be removed in order to separate the two halves. It is a little confusing saying “The bottom panel does not help gaining access to more screws. See next step.” I took that as being unnecessary, so skip.
Takkens Shoes - 답글
I was able to fix my speaker inside it i got this alarm at a thrift store for cheap turns out the one wire just needed a better conenction to get working thank you for the steps to get to it
johnstone1889 - 답글
The first photo of step 5 is a little misleading, it looks like you are unscrewing something, it made me look for the screws
Other than that this was very helpful, thank you
paulamicel - 답글
Thanks so much for this guide! The speaker in my H3510 had suddenly stopped working. I managed to take it apart with this guide. It turned out one of the wires on the speaker had come loose. We soldered it back on and that fixed it!
heleen - 답글
Thx!. Now I am able to fix the power cord which was often unplugged. So i soldered the power cable fixed to the pcb.
pibi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 79
30일 전: 293
전체 시간: 17,178
