주요 콘텐츠로 건너뛰기
Photive Artisan Portable Bluetooth Speaker Front Panel Replacement
필요한 것
  1. Photive Artisan Portable Bluetooth Speaker Front Panel Replacement, Front Panel: 1 단계, 이미지 1/1
    • Before continuing, be sure your device is powered off.
    • Remove two 9mm Phillips #0 head screws from the bottom side of the speaker.
  2. Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 2 단계, 이미지 1/1
    • Peel back the rubber feet from either side of the base.
  3. Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 3 단계, 이미지 1/1
    • Remove four 9mm Phillips #0 head screws from the bottom of the speaker.
  4. Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 4 단계, 이미지 1/1
    • Separate the base of the speaker from the upper housing.
  5. Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 5 단계, 이미지 1/1
    • Remove four 9mm Phillips #0 head screws from the inside of the speaker case.
  6. Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 6 단계, 이미지 1/3 Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 6 단계, 이미지 2/3 Photive Artisan Portable Bluetooth Speaker Front Panel Replacement: 6 단계, 이미지 3/3
    • Remove all cable connectors from the speaker motherboard.
    Emerson speaker Battery pack size
    Dion - 답글
결론
David Lennon
회원 가입일: 04/14/15
9,944 평판
안내서 10개 작성하였습니다
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 45개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 448
