주요 콘텐츠로 건너뛰기
Photive Rain Speaker Replacement
필요한 것
  1. Photive Rain Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Carefully remove the front panel from the device.
  4. Photive Rain Speaker Replacement: 4 단계, 이미지 1/1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  5. Photive Rain Speaker Replacement: 5 단계, 이미지 1/2 Photive Rain Speaker Replacement: 5 단계, 이미지 2/2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
결론
다른 2명이 해당 안내서를 완성하였습니다.
abcdef ghijk
회원 가입일: 02/15/16
723 평판
안내서 4개 작성하였습니다
IUPUI, Team 1-4, Harley Spring 2016 IUPUI, Team 1-4, Harley Spring 2016 회원
IUPUI-HARLEY-S16S1G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 307
