주요 콘텐츠로 건너뛰기
Picture Frame Matting Replacement
필요한 것
  1. Picture Frame Matting Replacement, Picture Frame Matting: 1 단계, 이미지 1/1
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: 2 단계, 이미지 1/1
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: 3 단계, 이미지 1/2 Picture Frame Matting Replacement: 3 단계, 이미지 2/2
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: 4 단계, 이미지 1/1
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: 5 단계, 이미지 1/1
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: 6 단계, 이미지 1/2 Picture Frame Matting Replacement: 6 단계, 이미지 2/2
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: 7 단계, 이미지 1/1
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: 8 단계, 이미지 1/2 Picture Frame Matting Replacement: 8 단계, 이미지 2/2
    • Rotate the backing clips under the frame to secure it.
결승점
Leah
회원 가입일: 01/20/23
160 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 18
전체 시간: 203
